Path template doesn't work
Hello everyone,
i have a problem. I wrote a basic xml template, and it doesn't work. XML doesn't have any mistakes. Below is my program:
<RobotController Name="Abb-Rapid" Version="All">
 <Actionlist>
  <Action Name="SetColor" LocRange="First">
  <Color Value="YELLOW"/>
  </Action>
 </Actionlist>
  <ActionFilter>
  </ActionFilter>
</RobotController>
When i try to apply it in "Apply Path Template Action" i see this window. Przechwytywanie.PNG
When i press sellect nothing happend. Template is placed "PathTemplateConfiguration" folder, and saved as XML, also RCS work properly. What is wrong? Why i can't select any action?
I attach XML file.
Re: Path template doesn't work
Siemens Legend Siemens Legend
Siemens Legend
hello,
there is a small typo error in the xml:
instead of Actionlist should be ActionList
Thank You. It's solved my problem!
