Placement Manipulator lost
Hi, I'm using 8.2 PD and PS. The Problem is that the dialog box for placement manipulation doesn't appear when I'm using PS. In PD it works. I know it's just a small problem, but it's really annoying. I can move the object in the graphic viewer by using the appearing frame. To close it I have to push alt+F4. How can I get the dialog box back.
PS: Same Problem for RoboJog
Re: Placement Manipulator lost
13. Robot Joint Jog doesn't open
Solution : REGEDIT remove key Commands Info (with contents) under HKEY_CURRENT_USER\Software\Tecnomatix\TUNE\NewAssembler\
Thanks. It worked
