Problem during uptate eMServer after choosing some Robot Controller
 A few days ago we did a pack n go to change a project from a server to another. The PnG worked fine and now we have the same project in this new server.
But now when if I choose a controller of some Robot diferent than Default the process is no longer able to update the em server, it gives a message:
Looking at a log I notice this warning:
[163972122:2248] DgStreamUpgradeLockedCommand.cpp(564) DG:WARNING> Object #9F94F197-86EB-4A50-90AE-6B5C003B3BDC of PmToolInstance does not have a field called 'workToolTCPF'stance does not have a field called 'w @ Wed Oct 04 08:55:23.637, 2017
[163972122:2248] DgStreamUpgradeLockedCommand.cpp(564) DG:WARNING> Object #759E2797-55AE-4D03-AE74-58AEEBFFDDAB of PmToolInstance does not have a field called 'workToolTCPF'stance does not have a field called 'w @ Wed Oct 04 08:55:23.637, 2017
[163972122:2248] DgStreamUpgradeLockedCommand.cpp(564) DG:WARNING> Object #DD0CB9F5-C4CE-41E3-B858-F5342C8C463D of PmToolInstance does not have a field called 'Controller'Instance does not have a field called 'w @ Wed Oct 04 08:55:23.652, 2017
[163972122:2248] DgStreamUpgradeLockedCommand.cpp(564) DG:WARNING> Object #DD0CB9F5-C4CE-41E3-B858-F5342C8C463D of PmToolInstance does not have a field called 'ControllerVersion'e does not have a field called 'C @ Wed Oct 04 08:55:23.652, 2017
[163972122:2248] DgStreamUpgradeLockedCommand.cpp(564) DG:WARNING> Object #DD0CB9F5-C4CE-41E3-B858-F5342C8C463D of PmToolInstance does not have a field called 'workToolTCPF'stance does not have a field called 'C @ Wed Oct 04 08:55:23.652, 2017
[163972122:2248] DgStreamUpgradeLockedCommand.cpp(564) DG:WARNING> Object #PP-TECNO-29-8-2017-8-27-34-61-63385 of PmToolInstance does not have a field called 'workToolTCPF'nstance does not have a field called 'w @ Wed Oct 04 08:55:23.652, 2017
[163972122:2248] DgStreamUpgradeLockedCommand.cpp(564) DG:WARNING> Object #PP-TECNO-29-8-2017-8-27-36-61-63411 of PmToolInstance does not have a field called 'workToolTCPF'stance does not have a field called 'wo @ Wed Oct 04 08:55:23.652, 2017
[163972122:2248] DgStreamUpgradeLockedCommand.cpp(564) DG:WARNING> Object #9E1E6623-AAD0-4278-B472-5B72A8C42DCC of PmToolInstance does not have a field called 'workToolTCPF'tance does not have a field called 'wo @ Wed Oct 04 08:55:23.652, 2017
[163972122:2248] DgNodeUpdater.cpp(204) DG:WARNING> Object #141389 Of class PmToolInstance does not have a field called 'workToolTCPF'. @ Wed Oct 04 08:55:26.170, 2017
[163972122:2248] DgNodeUpdater.cpp(204) DG:WARNING> Object #138768 Of class PmToolInstance does not have a field called 'workToolTCPF'. @ Wed Oct 04 08:55:26.170, 2017
[163972122:2248] DgNodeUpdater.cpp(204) DG:WARNING> Object #136160 Of class PmToolInstance does not have a field called 'workToolTCPF'. @ Wed Oct 04 08:55:26.170, 2017
[163972122:2248] DgNodeUpdater.cpp(204) DG:WARNING> Object #142522 Of class PmToolInstance does not have a field called 'Controller'. @ Wed Oct 04 08:55:26.186, 2017
[163972122:2248] DgNodeUpdater.cpp(204) DG:WARNING> Object #142522 Of class PmToolInstance does not have a field called 'ControllerVersion'. @ Wed Oct 04 08:55:26.186, 2017
[163972122:2248] DgNodeUpdater.cpp(204) DG:WARNING> Object #142522 Of class PmToolInstance does not have a field called 'workToolTCPF'. @ Wed Oct 04 08:55:26.186, 2017
[163972122:2248] DgNodeUpdater.cpp(204) DG:WARNING> Object #177014 Of class PmToolInstance does not have a field called 'workToolTCPF'. @ Wed Oct 04 08:55:26.186, 2017
[163972122:2248] DgNodeUpdater.cpp(204) DG:WARNING> Object #177045 Of class PmToolInstance does not have a field called 'workToolTCPF'. @ Wed Oct 04 08:55:26.186, 2017
[163972122:2248] DgNodeUpdater.cpp(204) DG:WARNING> Object #138701 Of class PmToolInstance does not have a field called 'workToolTCPF'. @ Wed Oct 04 08:55:26.186, 2017
Somethins is missing in this new server, but I dont now how to put it there.
Any help?
Re: Problem during uptate eMServer after choosing some Robot Controller
You need to import the robotics customization in your new Oracle schema (from eMPower\InitData\RoboticsCust)
Thanks GillesVelay once again!
It fixed the problem
