Problem in debugging mode creating TxPlcLogicBehaviorFunction .Net
Hi
I there any way to debug in visual studio with logic behaviour function so that from example a break point works and is not ignored at the moment it is just getting passed over
10 REPLIES 10
Re: Problem in debugging mode creating TxPlcLogicBehaviorFunction .Net
Never had any problem with Debugger and breakpoints in
TxPlcLogicBehaviorFunction.Evaluate()...
The debugger has of course to be connected with the PS-process, which is eMPower\tune.exe
You can either connect to an open PS: in VS press CTRL+ALT+P and attach to tune.exe
Or you directly start PS from the debugger (F5), nice because it can automatically load your test-data:
Is it also possible to open a new Study with this command?
Best regards,
Mario
Sure, just set "tune.exe" as external program and " /c NewAssembler /l offline" as command line arguments.
but then it opens with no study open, not with a new one.
Just go to PSR -> File -> New Study...
but thats what I don't want to do Smiley Happy
what I want to do is a command that starts a new study and generates the model automatically though the API.
Sorry, I do not understand. I thought you wanted to debug a user logic block function...
oh no. sorry for baffeling you.
I just replied to GuidoDamm's post with the debug command because I wanted to modify it.
RobSimCoder was the one who wanted to debug the logical behaviour function.
