Problem with robot viewer (Robot expert)
hello
I have a problem with the viewer robot.
according to what I have understood this option allows the export of graphs and data for further analysis, however to get processes more than 100 seconds robot expert begins to erase the first data in order to obtain the following.
There any way to get all the data?
In the case presented are deleted the first 15 seconds
Re: Problem with robot viewer (Robot expert)
Try to change the Display Range in the Settings (the button at top of the Robot Viewer window).
Dave
thanks, that was the solution
