Process Simulate 11.1 Standalone Upgrade CO to ver
Hi everybody,
is it possible to import robcad robot model into PS Standalone?
The "Upgrade CO to version" command is not active.
Dave
Re: Process Simulate 11.1 Standalone Upgrade CO to ver
In a cmd Window you can write upgradetoversion -comp "full path to your .co" -co2jt
That should give you a .jt file that you can insert in your 11.1 disconnected
/andreas
This method is successful only for some robcad models from GTAC (for example Mitsubishi dt_k10.tar.gz gives error).
Anyway, thank you very much for the reply. It help me with most of the models.
Dave
Hi
Have you tried the command on the .tar.gz file? It needs to be unzipped first (but I guess you tried that also-or
Andreas)?
Smiley Happy Certainly I've tried it on the unzipped folder. And right now, just for sure, I've also checked if it works on tar file. - NO
The error message for standard (unzipped) data :
** Update Engineering Data Version Tecnomatix 11 **
Upgrading component's approximation: d:\t\dt_k10.co ...
Failed to update approximation of d:\t\dt_k10.co.
Generating kinematic data (.m file) for component: d:\t\dt_k10.co ...
Failed to generate kinematic data (.m file) for component d:\t\dt_k10.co.
Upgrading component: d:\t\dt_k10.co ...
Updating component's materials: d:\t\dt_k10.co ...
Failed to update d:\t\dt_k10.co.
Failed to update materials of d:\t\dt_k10.co.
 Probably damaged data?
Hmm can't think of anything that might result in this operation failing, except if it is a super-component- have you checked that?
Sorry for not being able to figure out some more solutions😔...
Andreas
Thank you. You helped me anyway.
Dave
