Process Simulate - Blank navigation tree on client install
Hi All,
We have just installed a new machine with process simulate 10.1 as a client only. Everything appears to be working up and till we open only of our projects from the emserver. It appears to load something but the navigation tree is completely blank! The history shows nodes that we have navigated to but nothing appears if selected.
Any Ideas? Is there a potenial issue with communication back to the emserver?
Duncan.
Re: Process Simulate - Blank navigation tree on client install
I have the same problem , have anyone found a solution ?
I believe you are excuting the right PS-icon? So you get your usual login window?
Hello  GuidoDamm,
yes i am executing the right PS - icon .
I have an emserver with an oracle database on a machine and the client on other machine . On the server machine , i can acces the project and the navigation tree works fine .
On the client machine , i can acces the project , i open it but in navigation tree is nothing displayed ( not even the project name ) .
Do you use the same "customization" for both machines?
Hello , i`m using default customization for both . I didn't load any other customization /
