Process Simulate Custom XML Path Template
It is possible to set a "RX" Complex dynamic parameter via Path template?
In my case i will set the fanuc "TimeDistance Condition" parameter.
in XML desc. is the paramater not "RW" but "RX"
how can i write these dynamic parameter via path template?
thanks
Kind regards,
Benjamin Voelzke
Re: Process Simulate Custom XML Path Template
currently not possible, but you can set the raw robotic parameters (that you can see with "Robotic Parameters Viewer").
thanks,
what a pity
for ps 12.1.3 is the robotic parameter viewer not available.
Kind regards,
Benjamin Voelzke
12.1.3 tools and controllers will soon be available on GTAC.
its works.
But the robotic paramater Viewer is missing on GTAC for version 12.1.3.
thanks
Kind regards,
Benjamin Voelzke
