ROBOTEXPERT trial installation error
When I wanted to install the RobotExpert trial, an error occurred. I have attached the screen shot. Please help me with this problem.
Saeideh
Re: ROBOTEXPERT trial installation error
did you check if the file exists in you install source ? Maybe it did not extract properly.
If all ok, I believe your path might be too deep.
Windows has some restrictions here.
Try moving it from your desktop to a location that is several folders up.
Thank you very much for your help. I moved the folder to drive D and I
installed the RobotExpert successfully. But now I con not launch the
software and it tells me that "license not found". I have attached the shot
screen. Would you please help me again?
Thank you.
Saeideh
I myself solved this problem. Thank you for helping me.
Now I am starting to use RobotExpert trial. Smiley Happy
Thanks again.
Saeideh
