Rename Function F2 is not working in Process Simulate
I have started facing a unique problem in Process Simulate. Im unable to rename the resources in object tree and Operations tree using F2 function key or by any other command. Only possible way for Operations tree is to go to Operation properties and rename. And for object tree items, Process Designer is only the way to rename. by the way F2 is working in Process Designer.
What am I missing here. Is it a bug or any other accessability problem.! Any soultions..!
Thanks in advance.
Re: Rename Function F2 is not working in Process Simulate
Siemens Legend Siemens Legend
Siemens Legend
Which Tecnomatix version are you using?
In certain versions, if the "Display object caption" check box is checked, then editing of object names is blocked. This option can be set in the Options dialog under the General tab.
Kind regards,
Zachi
