Replace Connection Equivalent.
I've had some products that need updating to a different revision... In Robcad this wouldn't really be a hindrance as I'd just use the Replace Connection command. Though I'm currently using PS 14.1.1, is there command equivalent?
Thanks in advance,
Cameron.
Re: Replace Connection Equivalent.
Siemens Legend Siemens Legend
Siemens Legend
Hi Cameron.
If you are using eMS, check the Replace Object or Replace Resource Prototype commands. The descriptions are found in the online help for Process Simulate.
Ray
