Robcad - Segmentation fault - nucleus_stat
Hello all,
I'm currently using Robcad 9.0.1 and I'm getting the following message when I try to open the software:
C:\Robcad\data>sh C:\Robcad\/bin/robcad.sh
segmentation fault
[1] + Done(139) ${nucleus:=nucleus} $logflag $logfile $menu
4612 Segmentation violation C:\Robcad\/bin/nucleus_stat
killed
Does anyone know what can be happening and what can be done in order to correct?
Thanks!
Re: Robcad - Segmentation fault - nucleus_stat
You should connect to Support with rellevant data and description
Robcad 9.0.1 does not support any more.
What os you are using ?
It happened on Win7 and Win10, both x64.
The only solution I found is to format the PC and intall everything again.
