Robcad installer information: MKS_64bit
Hello Everyone,
I have been trying to install RobCad. But everytime I go past "Default selection". I get this error: The files for installation requirement MKS_64bit could not be found. The installation will now stop. This probably due to failed or canceled download
+ Windows 7 64-Bit
+Ran the runme.exe as administrator and User Account control is diabled
Re: Robcad installer information: MKS_64bit
Which Robcad version is it? Early versions (probably pre-9) did not support 64 bit on Windows.
Do you have a full distribution set?
Check MKS directory and toolkit64x.msi file in it.
Regards, Vladimir.
