Robot Expert Trial Closes
A user downloaded a Robot Expert license v12.0TR1 but the program closes right away after opening the Tecnomatix Image. Is there any way to check what is wrong?
License expiration date is ok.
4 REPLIES 4
Re: Robot Expert Trial Closes
Siemens Genius Siemens Genius
Siemens Genius
Please verify that your graphics card driver is the latest one available.
Is there any hint in the log file? Log file details can be set via the RobotExpert Doctor Tools menu.
Gil.
I have come across something similar already. Problem was caused by the bad installation. The question is: Has RE worked before?
If not and the problems are from beginning, try to uninstall RE completely (maybe you will have to clean registry and some shared folders too) and then reinstall RE again. Before the second installation I suggest to switch off the User Account Control.
Dave
I recently ran into this at a customer site, turned out to be the processor was an i3.  From the HW requirements:
CPU Minimum - Quad Core Duo
(i5)
Optimal - Quad Core Duo
(i7)
AFAIK there is no official support for onboard graphics.
But I already came across a machine using Intel HD graphics that caused the same effect/crash.
This was really solved by installing the latest driver from Intel.
Siemens Industry Software GmbH & Co. KG; Anschrift: Franz-Geuer-Str. 10, 50823 Köln;
Kommanditgesellschaft: Sitz der Gesellschaft: Köln; Registergericht: Amtsgericht Köln, HRA 28227;
Geschäftsführung und persönlich haftender Gesellschafter: Siemens Industry Software Management GmbH;
Geschäftsführer: Urban August, Daniel Trebes; Sitz der Gesellschaft: Köln; Registergericht: Amtsgericht Köln, HRB 70858
