Robot expert 13.1 unable to install
Hello
          I already installed tecnomatix 13.1 in which i have robcad, process simulate and process design. Now i am trying to install robot expert 13.1 but it is showing attached error.
Re: Robot expert 13.1 unable to install
Why you need to install Robot Express with PD PS Robcad installed on same machine?
robot expert is the subgroup of process simulate ( Or call it simplified version). the installation structure is same as that of process simulate. that is why you got this error info.
if you installed PS, don't install robot expert on same PC.
