Robot kinematic
Hello!
I want to create a kuka robot with custom limits. But i don't understand how can i create a secondary joints.
In first screen - the web-site robot (only 6 joints is visiable). in second screen - my robot with all joints
Снимок1.PNGСнимок2.PNG.
Re: Robot kinematic
what do you mean by "secondary joints"?
Joints that depend on others?
This is set in "Joint Dependency" ->5th buttons in Kinematics-Editor.
Re: Robot kinematic
Thanks for help. My problem is that I was asking the wrong joint axis line. Now everything is OK.
Re: Robot kinematic
I would like to ask you,if you can help me with robot kinematics with balancer? I did kinematics with crank, but I couldn´t set a limit axis, because limit of axis in kinematics was smaller than real limit.  When I did simply kinematics so balancer isn´t move...
