Robot or process simulate
Hello, I would like to know if it is possible to do this type of operation with Robo expert or Process Simulate. Follow the video.
Re: Robot or process simulate
Your application watched from video is robot pick and place and deburring. those two operations could be included in both Robotexpert and Process Simulate. But please make sure that if you need to include PLC stuff in your simulation. You must choose Process simulate. if you don't care PLC and just want to simulate prcess in one cycle. you can choose Robot Expert which is much cheaper than process simulate.
Hope it helps bit.
