Rope Simulation with Process Simulate
I want to simulate a crane in Process Simulate. It would be nice, if the hook is conneceted to the trolley by a rope. The rope has to chance its length when the hook is moving up and down.
Is it possible to create something like a rope in Process Simulate?
Re: Rope Simulation with Process Simulate
The only way to do this is creating the rope as a telescope.
E.g. add a driving joint, and a joint for each segment-link of your rope.
Dependent on your model you may use formula or leading joint for all your joints.
