Survey: Auto generate a Process Simulate Model
Hi everybody,
I am currently writing my master thesis and my goal is to develop a concept for the automatic model generation in Process Simulate based on a metamodel (which is also defined by me).
I want to write a Plug-in, which analyzes the metamodel and generates the model by using the Process Simulate API.
Since I write my thesis at a R&D department, we are lacking a little bit of workflow information. I hope you can help me getting a broader overview:
  1. If you start modelling in Process Simulate, which information is already available and in which data formats.
  2. How far is it useful to generate the model and when is it more useful to work in Process Simulate.
  3. Where do you get Information about modelling Operations, Modules and Logic Blocks from and again in which formats?
  4. What would you like to see included in the meta model?
Thank you very much in advance.
Kind regards,
