Teamcenter on Process Simulate
Hello community
I need to create a process on process simulate on teamncenter and make use of Appearances. My problem is that I dont know how I have to set the process in teamncenter in order to have the product within the part folder in Process Simulate and being ablo to creata appearence.
As can be seen in the next picture the crankshaft is placed within the process called ROOT_OP but when I send this process to process simulate it appear within assigned prototypes instead of within parts folders (see second picture)
Can someone explain me how should I build the structure in TC in order to have inside Parts folder in Process Simulate and being ablo to create appearances? What I did wrong?
thanks in advance
Re: Teamcenter on Process Simulate
Objects pop-up under "Assigned Prototype", when they are not contained by any Assembly-/Plant-structure that is currently loaded in your collaboration context.
Create an assembly-structure in your CC, paste the part underneath, and underneath your process/study.
Reload the CC, then reload your process in PS.
Then it should be loaded under "Parts" in object-tree.
how do I create and assembly-structure?
