Technical difference b/w Robotic Process Automation (RPA) and Test Automation Tools?
I've worked with test automation tools and know technically how it works, basically record (generate scripts) and replay (the generated scripts with data).
Now I heard of RPA, and people tell me its advantage is handling non-structured process, pattern, and data. I want to know how exactly RPA does the work, how much different from the record and replay?
Thank You
Honey Asin
Re: Technical difference b/w Robotic Process Automation (RPA) and Test Automation Tools?
are you sure you are posting in the right forum?
This is about automated manufacturing, involving robotics.
Test-automation is not the focus here.
BTW: what's a non structured process? We plan and verify (well structured) manufacturing processes. Including resources, operations and consumed/produced parts.
