Do you mean
Reply
Solved! Go to solution
The edited Pose lists will not be saved with my net.api code
I copy a resource in Process Simulate Disconnected and add a new pose in the pose list. Then I save the resource. For this i use the net.API interface. My problem now is that the edit poselist ist not saved in the .jt which i make with code underneath.
Can you help me?
Maybe they see a bug in my code!
'Code add new Pose in Poselist
Dim l_joint As TxObjectList = l_Cto.PoseList
If l_joint.Count > 0 Then
Dim name As String = "R"
Dim poseData As New TxPoseData
Dim valuepose As ArrayList
valuepose = poseData.JointValues
If list(0).ToString = "Stift" Then
oeffnen = list(1)
valuepose.Add(oeffnen)
ElseIf list(0).ToString = "Spanner" Then
oeffnen = list(1) / 180 * System.Math.PI 'Umrechnen Rad in Grad
End If
poseData.JointValues = valuepose
Dim instance As New TxPoseCreationData(name, poseData)
l_Cto.CreatePose(instance)
End If
'Code Save New Ressource
Dim LibData As TxLibraryData = New TxLibraryData(ZielOrdner, name2)
If TypeOf storage Is TxLibraryStorage Then
Dim libStorage As TxLibraryStorage = TryCast(storage, TxLibraryStorage)
Dim localStorage As TxLocalStorage = libStorage.CopyToLocal
localStorage.SaveToLibrary(LibData)
ElseIf TypeOf storage Is TxLocalStorage Then
Dim localStorage As TxLocalStorage = TryCast(storage, TxLocalStorage)
End If
Solution
Solution
Accepted by topic author A-S-E
‎08-26-2015 04:32 AM
Re: The edited Pose lists will not be saved with my net.api code
--> instance.CreateAtInstance = false
Thank you! It works.
