Tool data can not be changed.
Process Simulate, Fanuc robots.
Did a lot of robots and found one problem on one of them. This robot comes with pre-defined tools ,as all others, but in this case tool data can not be changed.
The question is - how can I change the tool? is there any mechanism in PS that is able to lock the tool?
Re: Tool data can not be changed.
If your UTool 1 is defined as a Physical Robot TooBox WorkTool (instead of as a system frame robot.ut1), then you cannot change it from Robot Setup but have to change it from Robot ToolBox.
great! Thank you,it works!
