Upload ABB robotic program with RelTool command
Does anyone have experience with upload of the RelTool command for ABB robots?
When I am trying to upload a RelTool position with the ABB-Rapid controller, all RelTool Move positions ends up in world zero.
Is there a way to solve this?
Best regards,
Henrik
Re: Upload ABB robotic program with RelTool command
Yes it is possible, you need to create a custom XML for "MotionConfiguration" that allows you to upload all MOVE commands in the correct way.
A description of how to create a custom XML you will find here:
C:\ProgramFiles\Tecnomatix\eMPower\Robotics
Best regards,
Patrick
hello,
a easy way is not avialable.
for these case you must create your own custom xml files.
you can see a example in controller help.
abb_rapid_user_manual.html
and
RoboticsCustomizedUIManual.pdf
Kind regards,
Benjamin Voelzke
correct patrick.
Kind regards,
Benjamin Voelzke
Thanks guys!
I know about this, my hope was that someone already has written some tags in an MotionConfiguration xml-file that could handle a Move RelTool upload Smiley Happy
Best regards,
Henrik
