Upload Robotexpert
Hi All
With robotexpert and Olp kuka, I can upload full backups from a robot KRC2 or also need the RRS?.
What I need is to upload the robot trajectories to robotexper, that way I do?
Re: Upload Robotexpert
You do not need the RCS module to upload. You can select "Rcs Decouple" for non simulation action in Robot Properties / Robots Settings.
Thank you very much for your help
