automating analyze schema in the Technomatix Admin Console
Hello, I am looking for away for me to automate the analyze schema in the Technomatix Admin Console. I have to run this every day right now I do it maunally during lunchafter getting users out
but i would like to be able to run this at night when no one is here. is there any scripts or command line .bat files?  Your help would be apprciated thanks
Re: automating analyze schema in the Technomatix Admin Console
Siemens Genius Siemens Genius
Siemens Genius
Hi.
This information is available as a Solution article in GTAC:
These steps in AdminConsole:
1. RUN "REFRESH SCHEMA" UNDER SOFTWARE DEPLOYMENT
2. RUN "RESET ADVANCE QUEUE" UNDER SCHEMA ACTIONS
3. RUN "ANALYZE SCHEMA" UNDER SCHEMA ACTIONS
Can be automated by running the following commands in the following order in batch on the eM-Server:
DbUserAdmin -refreshschema -- -svr XXXXX -usr YYYYY -usrpswd ZZZZZ
DbUserAdmin -initAQ -- -svr XXXXX -schemaOwner YYYYY -schemaOwnerPswd ZZZZZ -aqUsr YYYYY_aq -aqPswd ZZZZZ
DbUserAdmin -refreshAccessUser -- -svr XXXXX -schemaOwner YYYYY -schemaOwnerPswd ZZZZZ -AccessUser YYYYY_EA -AccessUserPswd ZZZZZ
sqlplus YYYYY/ZZZZZ@XXXXXX @analyze_db.sql
(Replace all XXX, YYY, ZZZ with the relevant values)...
All user logins must be disabled during this process.
Disable login-->eMServerCMD.exe administrator n 0 disable_login_all
Enable login-->eMServerCMD.exe administrator n 0 enable_login_all
Thanks Ray this will be a great help
