background robot routine
Is there a way in the robot to run a background routine?
parallel to the normal robot program?
example:
robot starts with cell program
jump to path 1
     in background runs a small robot routine and check other parameters
robot drive and drive
Kind regards,
Benjamin Voelzke
Re: background robot routine
Simulation of parallel robotic routines is not supported. You might be able to emulate this behavior with Logic Blocks.
ok
thanks for your answer
Kind regards,
Benjamin Voelzke
