cancel
change weldpoint to via point
HI,
It is possible to change weldpoints to an via point ?
All points togeher in one path when possible.
thanks.
Re: change weldpoint to via point
HI,
it is possible to change a weld operation to a normal operation without weldpoints ?
thanks
In OlpTool, there is a command to convert weld locations to via locations.
hi,
thanks.
this tip was the solution !
