co to cojt
I could not import robcad co file to cojt by uprade to version. comes out an error. Normally i can open the co file into robcad.
Could you also try this file i have attached. Do we have any condition or boundaries at co file before transform it cojt.
Re: co to cojt
Hi.
This component is a supercomponent, but all the subcomponents are missing.  See the log snip:
Failed to load component x_5rc2850001.co.
@PIN_K_A_ROBOTS/br_282109.co - Prototype not found.
@PIN_K_A_ROBOTS/br_282110.co - Prototype not found.
@PIN_K_A_ROBOTS/al_261021.co - Prototype not found.
@PIN_K_A_ROBOTS/al_261032.co - Prototype not found.
@PIN_K_A_ROBOTS/el_149380.co - Prototype not found.
@PIN_K_A_ROBOTS/el_149384.co - Prototype not found.
@PIN_K_A_ROBOTS/x_5rc28.co - Prototype not found.
Failed to update approximation of component x_5rc2850001.co.
You must first gather all the subcomponents, and set the library root in the upgrade CO to version dialog. Also, you can only go CO to CO.  However, a JT file will be created.
