compare products in tecnomatix
Hallo,
in Catia we can use command "compare products" to compare two products and very quickly to konw what is the difference between two prodcucts,see attachment.Is there any similar command in process designer or process simulate?
Re: compare products in tecnomatix
At the moment, the function is only available in the VISMOKUP Teamcenter, not in Process Designer or Process Simulate.
Kind regards,
Benjamin Voelzke
