custom olp xmls
hello,
i have a question about custom xmls?
is there a way to read the path name in OLP command?
ex.
Path name in ps is "WELD_STATION_2020"
i will add an OLP command on path (not in first Location)
in my wish i add a olp command with custom xml and read the path name and create a header with the name.
thanks
Kind regards,
Benjamin Voelzke
Re: custom olp xmls
You have "OpName" dynamic parameter (see Olp-AddOn.xml).
