custom signal string for abb robot
hello,
it is possible to create a custom signal string for abb?
example ABB:
PROC MoveJ_JobRequest (num Job)
    WaitDI  [PLC_di_Job0[Job]_Enable]
example KUKA: (works)
GLOBAL DEF Job_req(Job_NR :IN)
$OUT[O_Finished_Job[Job_NR]]=FALSE
Re: custom signal string for abb robot
In principle, yes
funny  Smiley Happy
principle = yes
practical = no
How did you name the signal in PS?
signal name in ps
PLC        Robot Signal
20R01_PLC_di_Job01_EnablePLC_di_Job01_Enable
I did not understand you wanted to build the name of the signal by concatenating strings in ABB. Well this is indeed not supported.
yes this is my wish
example:
proc dummy( num value)
string1 [value] string2
input11_robot
