.gmsimperf file in .co
What does this file do?
Re: .gmsimperf file in .co
Siemens Legend Siemens Legend
Siemens Legend
that file is not directly used by any application. it can be deleted from the .co folder.
However if the .co has to be upgraded to be used by Process Simulate, it will be used to create the jt file. In case you don't have Robcad installed, that .gmsimperf cannot be generated.
best regards
Benrard
Thanks for your reply.
If I delete it now, and later want to upgrade the component to cojt, will
it automatically be recreated or do I take any action?
Rgds Kåre
Siemens Legend
Hi Kåre,
uogradetoversion can regenerate it (co to co, keep gmsimperf options)
Best regards
bernard
