high resolution screenshot from ps
hello,
is there a way to create a high resolution screenshot from ps cell?
with picture export the quality is not so good.
i search a way to create a big big picture from complete plant (ps cell). for painting
thanks
Kind regards,
Benjamin Voelzke
Re: high resolution screenshot from ps
Hi Ben,
this has been nicely removed in Standalone version.
I believe in eMS-version, the attach-file function still supports defining the resolution.
But you could write out using API-method
TxApplication.ViewersManager.GraphicViewer.GetImage()
Resolution seems not limited. I created images beyond 10kx10k pxls.
Guido
hi,
You can use following option to get good picture
Hello expert,
can you tell me how.to use this API step by step?
I also encounter.the same problem to.export.the section of collision.
thanks.
paul
You'll need a development environment for dotnet languages, like MS Developerstudio and some programming skills in any dotnet language.
eMPower/SDKhelp contains a help file, which has a chapter about how to create a button in PS. If registered and added to you GUI, a click on the button can execute that function.
This forum also has a section discussing programming and API questions.
