how to get cojt folder path in the OLP code?
Hi all:
   I want add a version information file in the cojt folder while inserting component.
But, I donot know how to  find the cojt folder in the code.
I think the class Tecnomatix.Engineering.TxLibraryStorage may be work, as show:
    public sealed class TxLibraryStorage : TxStorage
        public string FullPath { get; }
        public bool HasDetailedRepresentation { get; }
        [Obsolete("For getting component path use the new FullPath property")]
        public TxLibraryData LibraryData { get; }
        public TxLocalStorage CopyToLocal();
        public void Reload(TxRepresentationLevel representationType);
But I dont know wether this class is I need, and also dont how to use this class!
Can somebody give me some tips?
thank you !
3 REPLIES 3
Betreff: how to get cojt folder path in the OLP code?
what do you mean with OLP code?
With API you can use the Full path property of TxLibraryStorage.
Have a look to the Tecnomatix Developer Forum Smiley Wink
@MarkusH wrote:
Thx for your reply!
OLP is one module of tecomatix.
I found the TxLibraryStorage API , but I dont know how to use?
I also find a post on another question, as :
ITxObject obj = TxApplication.ActiveSelection.GetItems()[0];
ITxStorable storableObj = obj as ITxStorable;
if (storableObj != null)
    TxLibraryStorage libraryStorageObject = storableObj.StorageObject as TxLibraryStorage;
    if ((libraryStorageObject != null) && libraryStorageObject.HasDetailedRepresentation)
        try
            if ((obj as ITxComponent).RepresentationType == TxRepresentationType.United)//if the representation type is Detailed, then it is already in entity level.
                libraryStorageObject.Reload(TxRepresentationLevel.Detailed);
        catch (Exception e)
But I got  storableObj is null.
I'm not good in C#, but how about this:
private string GetObjectsCojtPath(ITxObject obj)
   TxLibraryStorage stor = obj.StorageObject as TxLibraryStorage;
   if (stor != null)
      if (stor.FullPath != null)
      return stor.FullPath;
return "";
