how to import the robot path
Not applicable
I would like know as import path on robot expert.
8 REPLIES 8
Re: how to import the robot path
Not applicable
To import path from physical robot (upload) you can use options available in Robotics -> Robot Program -> Robotic Program Inventory (Upload Program). But as far as I know you need controller which is not included to RobotExpert demo. If you have path from Robcad you can probably import by using "Upload Robcad Robotics Program".
Siemens Genius Siemens Genius
Siemens Genius
Please clarify your question. Where do you want to import your path from? other simulation tool? CAD application?
Generally speaking, RobotExpert provides good tools to generate robot path based on product geometry and 3D curves that you can import or create.
Let me know if this helps.
Gil.
Not applicable
I will like know as create locations on part.
Siemens Genius
Please follow the QuickStart movies that show step by step workflow.
You can also read the Quickstart guide for more help.
Gil.
Not applicable
Ok friend thanks a lot.
Siemens Genius
Let me know if you do not find the movies or guide.
Gil.
Not applicable
I have the movies and guide.
Not applicable
the topic Create Arc Mfgs using Modeling Capabilities speak an little as make for create the locations in the part, but is very simple.
