keeping an appearance displayed line sim.
Hi!
I'm in line simulation mode and I'm starting a object flow operation from a PLC, by moving a part a sensor is being triggered. By triggering the sensor a robot program is started. Now, the part/appearance from the object flow operation dissapears after the robot program has finished.
How do I keep this part displayed after my robot program had ended?
Best Regards
Re: keeping an appearance displayed line sim.
Add a non-sim-operation in material-flow-viewer after your robot operation and give it a “false” as transition expression so it’s never started.
Siemens Industry Software GmbH & Co. KG; Anschrift: Franz-Geuer-Str. 10, 50823 Köln;
Kommanditgesellschaft: Sitz der Gesellschaft: Köln; Registergericht: Amtsgericht Köln, HRA 28227;
Geschäftsführung und persönlich haftender Gesellschafter: Siemens Industry Software Management GmbH;
Geschäftsführer: Urban August, Daniel Trebes; Sitz der Gesellschaft: Köln; Registergericht: Amtsgericht Köln, HRB 70858
Awsome, thank you!
