missing an easy sensor without check entity
I miss a simple sensor that component needs no control.
the sensor should easily all on collision check.
once a component touches this sensor, should he put the signal.
The problem is that at 1000 sensors any sensor by hand must be mapped to a component or resource.
Kind regards,
Benjamin Voelzke
