motion command explanation
I don't understand the customized motion commands.
Where is the different to Path Template Configuration?
Is it, that I at Path Template Configuration I can customize a whole path at the contrary at Motion Configuration I only can customize a single location?
I have not find good explanation wherefore I can use motion commands.
Ernie
Re: motion command explanation
Customized Motion Command is the mechanism to customize how a location is downloaded and simulated.
Path Template Configuration is a mechanism to automatically do a lot of things instead of manually, in particular setting a specific "Process Type" on locations that you want to customize. But you can do more.
