path via location mirror
Hello everybody,
i switched recently from Robcad to Process Simulate 11.1 so i´ve a basic questions.
I would like to mirror some via location in an operation by an certain frame an flip it afterwards to become the same orientation. (Background - partly symetrical part and welding points).
only found the solution to mirror the complete operation (operation->mirror) an merge it afterwards. By this function the robot and weldgun is mirrored to, which i don´t need.
Is there an uncomplicated way to become the same result?
Many thanks for reply
