permamently picture in OLP Command
i wrote an OLP Command and now i want to insert a permamently picture right after the Desciption of the OLP Command.
With:
<ComboDef>
<ElmDef Picture="picture.jpg">Open</ElmDef>
</ComboDef>
I only can insert a picture to the item inside the combo box.
Can anybody give me an advise.
Thanks!
Re: permamently picture in OLP Command
Hello ErnieH
You can use an empty default value to your combobox and assign a picture to it, so every time you open the command the picture will be there. Something like this:
<Param Name="Param" ValueType="string" Default="">
	<ComboDef>
	<ElmDef Picture="picture.jpg"></ElmDef>
	</ComboDef>
</Param>
Thanks for your answer.
This is not a bad solution. But one thing incommodes me. There is always an empty line.
But i think there is no other solution, right?
Hello!
You can set the default value to be, for example, the first item of your combobox list, so you'd not have the empty line.
Regards!
