problem abaut robot configuration
i have a problem when i do simulation.
if i select a weld location within an operation, and then select Robot Configuration. The Robot Configuration dialog is displayed(see attachment).But sometimes Robot Configuration dialog has displayed no robot solution and i can not teach the robot.what is the reason?
Re: problem abaut robot configuration
if there is not robot solution display, it is not possible to create a configuration for the actual position of the robot.
Then you have to change the orientation of the weld location or the position of the robots single axis to get possible robot solutions.
Thanks Patrick,
But How can I change the orientation of location or the position of the robot single aixs?
In addition to the message before:
If you have a location where you can not select a robot solution.
For this location try to redefine the tool and base data of this location.
Sorry,I don't understand "for this location try to redefine the tool and base data",how?can you send me some screenshot For exsample?
You first need to check if the location is reachable (via Jump Assigned Robot command). If the location is not reachable, then you will not get any solution in "Robot Configuration".
i redefine the tool ( welding gun) and base data ( robot) for the operation,but it displayed still no robot solution.
It's reachable.i can run the simulation of the whole operation.
Is your problem happening only on some locations in a given study or on all locations? In the second case, it might be missing configuration information in the robot motionparameters.e.
Hello Gill,thank for your help!all locations have problem.i think maybe the problem of robot prototype and I will try to change another robot.
