process simualte multi viewer graphic window
how  to get multi viewer graphic  window in process simulate
Re: process simualte multi viewer graphic window
It depends on your version of Process Simulate you use.
This feature is available from Tecnomatix 12.1.3.
In the Ribbon Menu -> View -> Screen Layout you will see commands like "New Window", "Arrange Window" and "Switch Window".
Best regards
Patrick
Thank you patrick.
venkatesh
