process simulate custom xml rrs file
i have a question about the rrs.xml file.
It is possible to deactivate version names in xml file via "!--  --" code?
i tested this but ps can not show controller after the comment out block!
next quesition:
I have custom xmls from OEM.
The OEM define a fix Version Name with custom path.
in my case i must dublicate the version to define a own custompath string. (ex. commissioning xmls)
The problem: i have two versions with same name: Version Name="krc8.x_G01"
in version 1 the custom path goes to OEM Folder
in verison 2 the custom path goes to my own folder
In PS i have no chance to see the difference.
Is there a solution?
thanks
Kind regards,
Benjamin Voelzke
