process simulate path template
hello,
is it possible to start the path template function with add path to path editor?
Kind regards,
Benjamin Voelzke
Re: process simulate path template
There is currently no API to start path templates. It can only be run from the dedicated command.
funny...
show these siemens clip on 11:00 min.
you can see 1 location is created. but on add operation to path editor created 2 loactions. one before and one after.
http://community.plm.automation.siemens.com/t5/Tecnomatix-Knowledge-Base/How-to-Program-Industrial-R...
Kind regards,
Benjamin Voelzke
Well, I was not aware of this capability. Hopefully someone else on the forum knows about it.
Could it be just keyboard shortcut?
D.
