process simulate version check in custom xml
good morning all together,
is there a way to check in custom xml the process simulate version?
my idea:
create one custom xml for abb.
in these xml i check the version.
if ps10.1 is install i work with old custom functions
if ps 12 install i can work with all new functions.
today i must create for all version complete new xml files.
that would be a nice improvement.
thanks
Kind regards,
Benjamin Voelzke
Re: process simulate version check in custom xml
That is indeed not supported.
anyway you can split your XML files in 3 files:
- common for all versions
- specific to 10.1
- specific to 12
Then you install 1+2 or 1+3 depending on the platform version.
It should not require more redundant XML code than checking the version in a single file.
ok i know your informaion.
but with single files you have more administration effort.
Kind regards,
Benjamin Voelzke
