project is corrupted when I save it,I cannot open it.
Re: project is corrupted when I save it,I cannot open it.
You can try to load your PSZ without the correct systemRoot set.
So you can find out the problem is caused by any component in your library.
If you still have the problem, it´s corrupt.
Best regards
Patrick
