Do you mean
Reply
Solved! Go to solution
"Edit Part Simulation Property List" problem.
I'm facing a problem with the "Edit Part Simulation Property List" option from CEE→Sensors→Property Sensor→, i am unable to add project properties, i tried almost everything... What should be done in order to activate "Add" button?
I am using Process Simulate 11.1TR3 Standalone.
Solution
Solution
Accepted by topic author ADD
‎08-26-2015 04:32 AM
Re: "Edit Part Simulation Property List" problem.
sry for the late response.
This is a bug that came in in TR3.
I'm not sure which versions are malfunctioning.
I just know it should be fixed in 12.1.1 that has recently been released.
Thank you for response. I will check it later, when I upgrade my PS to newer version.
