"Modify Color"-Dialog Customization
Hello everybody,
I've got a simple question:
Is it possible to set a custom name(or say alias) for the colors of the "Modify Color" - command in the ColorsDef.xml?
For Example: Set "Custom White" for "Hex={FF,FF,FF}" (see the attached screenshot)
Possible Syntax could be something like "<Color value="#FFFFFF name="Custom White" />""
Doe anybody know about such a functionality?
Best regards
Matthias
Re: "Modify Color"-Dialog Customization
yes, the ColorDef.xml (located in the installation folder) supports either the color code or the color name (as defined in :  http://www.w3schools.com/html/html_colornames.asp)
e.g. your ColorDef.xml can be something like:
<ColorDef>
  <ColorPalette>
    <UserCustom />
    <Predefined>
      <Color value="AliceBlue" />
      <Color value="AntiqueWhite" />
      <Color value="Aqua" />
in the same way, how can I get a new "Palette" or a second one?
I need the same "Palette" of Robcad at Process Simulate 11.1.
Thanks in advance.
