robot expert and equipment prototype
much functions in process simulate works only with equipment prototypes.
in robot expert is this type not available.
WHY?
Kind regards,
Benjamin Voelzke
Re: robot expert and equipment prototype
Siemens Genius Siemens Genius
Siemens Genius
Hello Benjamin,
Currently Equipment is not supported in RobotExpert.
Actually, it is only partially supported in Process Simulate - one cannot insert an equipment when working in Process Simulate Standalone or Disconnected, so reusing equipment and sharing equipments between disconnected studies is not supported at the moment.
We may consider to add this support to RobotExpert in the future.
What kind of workflows in RobotExpert require equipments and what kind of equipments?
Gil.
hello,
the equipment prototype is not the best solution but lot of feature build on these.
Dual Arm Robots or the most important think DRESSPACK on Robot!
